Please Help. Only have Reverse not drive
Hi everyone,
this is my first post here for my discovery 2 and am in a bit of a situation. After getting stuck going up quite the hill and giving it the berry’s my car was not selecting into any gear when going between Hi and Low. After some time we are able to get the car down safely and reverse began to work. I have seen a few posts on this issue but none that were able to help me at this current time. Has anyone had this issue before and got any fixes to it, as I am away on a trip and will have to leave the car on the side of the road overnight.
Thanks heaps
Tyler
Thanks heaps
Tyler
You can definitely check the fluid, but in all probability the front clutch is out. Trans has to come out to replace it. Not a common failure, more common in the early trucks than the late trucks. You can typically get a complete trans for less than $300 from a Disco breaker. Good luck.
Tyler135 (10-11-2020)
If you are going to do it you need about $80 in parts.
You need this from https://www.transmissionpartsusa.com/orders.asp
Items Ordered: Price: Status: $3.50 Shipped $4.29 Shipped $13.16 Shipped $24.00 Shipped
VIEW ORDER
And from these guys https://www.oregonperformancetransmission.com/ you need this:SUP-K002 Superior ZF 4HP22 Automatic Transmission Clutch Shift Correction Kit Replacement Seals ZF4HP22 $23.85
VIEW ORDER
