Please help power steering blow out:(
Got same problem, seems like the metal tube that goes around under the radiator was leaking somewhere. Im just wondering if that can be cut shorter or it has to loop all the way to the other end of the radiator and back. Is that something to cool the fluid as well? Mine just have too long tubing. 04 disco too.
It's not advisable to use compression fittings on the high pressure line. Cut out the bad section of tube and braze in new tube.
Like Joemomma mentioned. You could always cut it, and add an external cooler.
Now I understand. Seems like it. Coz anybody could have just cut the tubing short.
Would something like this will be ok to use?
https://jet.com/product/detail/4492f6b884c7463686bf81c96effe2b7?jcmp=pla:ggl:gen_ vehicles_parts_a2:vehicles_parts_vehicle_parts_acc essories_watercraft_parts_accessories_a2_other:na: na:na:na:na:2&code=PLA15&ds_c=gen_vehicles_parts_a 2&ds_cid&ds_ag=vehicles_parts_vehicle_parts_access ories_watercraft_parts_accessories_a2_other&produc t_id=4492f6b884c7463686bf81c96effe2b7&product_part ition_id=156920119740&gclid=COnH2N_j_MsCFQFkhgodzH gHAw
or this
http://www.summitracing.com/parts/de...FQckhgodvOEP9A
or this
