Please Help: Rear Propshaft removal
Old Jan 29, 2013 | 07:47 PM
antichrist's Avatar
A rotoflex absorbs driveline shock loading and also vibrations. The are quite common.
Old Jan 29, 2013 | 08:12 PM
TRIARII's Avatar
Originally Posted by jfall
Guys,
Forgive this perhaps obvious question.
I am more of a systems troubleshooter than a drive line guy.
With that said --
Is there a way to get a drive shaft with absolutely no rotoflexes?
Those seem like a "cheap" u-joint.
Why are there Rotoflexes and not U-Joints on a shaft?
Was it a way to decrease weight and just be cheap?
Or is there an advantage to a Rotoflex vs a U joint?
Seems the Discovery I has the advantage in this case?
I could be wrong so dont quote me but I thought early D1 models also had a rubber coupling on the one of its propshafts to?
I'm not sure why LR used rubber rotoflex couplings and I have no clue as to the pros and cons of them vs u-joints.
Old Jan 29, 2013 | 08:19 PM
hilltoppersx's Avatar
Originally Posted by TRIARII
I have found no indication regarding the correct direction for the rotoflex part. Could you elaborate? Because I did finally manage to remove the centering bushing thing, installed the new one and re-attached the propshaft to the truck. But if I did do it wrong then I will fix it tomorrow. and of course I used the new nuts and washers. Unfortunatly I forgot to install 7 washers! Kit came with 12 so I have to remove it tomorrow anyways to add the washers...
there should be an arrow on the rotoflex indicating the rotation direction of the shaft.
Old Jan 29, 2013 | 08:30 PM
jafir's Avatar
My d1 had a rotoflex.
Old Jan 29, 2013 | 08:32 PM
jafir's Avatar
I'm pretty sure you install the rotoflex so that you are squeezing the meatier portions, not pulling them.
Old Jan 29, 2013 | 09:22 PM
TRIARII's Avatar
I know the genuine rotoflex has the arrows but I did not notice any on the AB rotoflex, but Ill remove the part tomorrow after work and inspect it more closely. Also need to remove the spline and re-align it correct in the shaft.....
Old Jan 29, 2013 | 09:25 PM
TRIARII's Avatar
Thats what I thought. I remember know because when I called RoversNorth to order a replacement rear propshaft for my 98 D1, they asked me if I had the older rubber setup or the u-joint setup. At first I was completely confused by his question so he explained that early D1 models had a rubber flex coupler on the rear shaft then in either 1997 or 1998 they replaced the flex design with a u-joint setup.
TRIARII
Jul 27, 2013 06:42 AM
Jerry B
May 7, 2013 04:10 PM
TRIARII
Feb 4, 2013 11:03 AM
AuZZZie
Mar 13, 2012 06:58 AM
Robover01
Nov 19, 2009 08:25 PM
