Plugs and Wires
Old Jan 16, 2008 | 11:17 AM
brooksa's Avatar
Default Plugs and Wires
Need to do some maint. on my 04 SE7 with 64k, what are the benefits of using the Magnacor wires and the Platinum plus 4 plugs?
Andy
2004 SE7
2000 Ford Excursion
Old Jan 16, 2008 | 12:15 PM
mcneal's Avatar
Default RE: Plugs and Wires
Its just a good combination, for me it meant less misfires, which is always good
Old Jan 16, 2008 | 12:37 PM
S4poor's Avatar
Read on, this will help you.
http://www.magnecor.com/magnecor1/main.htm
Old Jan 16, 2008 | 04:07 PM
okdiscoguy's Avatar
You get a better burn which translates to less carbon deposits and better mileage.
Old Jan 16, 2008 | 06:02 PM
Iridium plugs need less power. Iridium plugs also get you more MPG than platnium. They last longer too.
No experiance with those wires though. Will try them next time. But I would bet the farm on the plugs.
Old Jan 16, 2008 | 07:25 PM
After 65,000 miles I switched from the Magnacor wires and Plus 4 plugs, which was a good combination for me, and went to the Bosch Fusion to see if they really made a difference.
As far as I can tell they did, raised my highway mileage by nearly 2 MPG.
Old Jan 17, 2008 | 08:41 AM
jspbtown's Avatar
Loved the Magnacor wires. Hated the install, but the car idles much better. Of course one boot was cracked which probablycaused mymoisture sensitive occasional misfire
Old Jan 18, 2008 | 07:31 AM
DiscoOn22s's Avatar
MIKE YOU SAY YOU HAD THE MAGNECOR'S WITH THE PLUS 4'S THEN SWITCHED TO THE FUSIONS. WHY WOULD YOU RECCOMEND ME THE PLUS 4'S?
2002 DISCO W/ 79000 MILES.
Old Jan 18, 2008 | 07:55 AM
jkid's Avatar
I think he only switched to the fusions fairly recently. The plus 4's have withstood the test of time though and have been proven fairly well to work good.
Old Jan 18, 2008 | 08:38 AM
The Fusions are pretty expensive and I am just wanting to see how well they hold up before I push them alot.
