Plugs and Wires
Old Dec 11, 2008 | 03:48 PM
  #21
NiteTrain's Avatar
Default RE: Plugs and Wires
I'm seeing some mixed reviews on these E3 plugs. Majority of reviews I've seen says they are great and improve fuel economy. A few said no change in fuel economy but seemed to improve power. One guy with a BMW said it ran so bad after installing them that he barely got it to the mechanic. I have a feeling this guy mixed up his plug wires. I'd still like to find somebody that has ran them in a rover.
Old Dec 11, 2008 | 07:25 PM
  #22
I dont know if you will find anybody who has ran them in their Rover.
After I install mine I will let you know, you will have to wait until spring though.
My 2001 Montero came with Denso Iridium plugs from the factory, At 70,000 miles I switched to the E3 plugs, better MPG, no noticable improvement in power.
I do not remember how much better MPG, it has been 3 years...
Old Dec 13, 2008 | 06:33 PM
  #23
jojoknox's Avatar
7th Gear
Just recently acquired 00 disco II with 104k and a stack of misfire codes. Swapped out wires and plugs with magnacores and plus 4s and also changed both coil packs while I had her all tore apart. Old plugs were pretty shot so my hopes were high for great improvement re; rough idle, poor performance,etc. To my dismay, am still getting misfire code for jug#8 and actually seems to run worse! Any thoughts on this?
Old Dec 13, 2008 | 07:42 PM
  #24
Double check your wires, making sure that they are not crossed and are allseated correctly.
Old Dec 13, 2008 | 09:00 PM
  #25
jojoknox's Avatar
7th Gear
Thanks for the good advice. Already checked on both counts; plus, figured it would misfire on two cylinders if wires were crossed? What else could cause a misfire on a single cylinder?
Old Dec 13, 2008 | 09:50 PM
  #26
jojoknox's Avatar
7th Gear
Well guess what? Brand spanky Bosch plus 4 had a generous split down the ceramic cone. Too obvious! Thanks again.
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
Chrisinhouston
May 2, 2010 09:15 PM
sparky
Defender
Jun 3, 2007 05:10 AM
