PO 734....Transmission Ratio Not Correct...Help, please..
Old Dec 11, 2009 | 06:01 PM
RoverLover21's Avatar
Default PO 734....Transmission Ratio Not Correct...Help, please..
What should this mean to me and how can I fix it?
Any help would be greatly appreciated.
Thank you.
Old Dec 11, 2009 | 06:10 PM
salve7's Avatar
I had a code like that but it was an incorrect 4th gear ratio... with that being said a new maf cleared it right up.
Old Dec 11, 2009 | 06:12 PM
Your MAF is bad.
It is sending a code that messes up the transmission and because the transmission has its own computer when it gets a bad signal from the MAF it does not know what to do.
DiscoMike knows this for 100% and I am 95% that is the problem.
No other warning lights?
The "M" and "S" lights are not flashing are they?
Old Dec 11, 2009 | 06:24 PM
no other warning lights, spike. "m" and "s" are not flashing. tranny seems to be shifting just fine. how can I fix this problem? is it safe to be driving my rover around?
Old Dec 11, 2009 | 06:27 PM
what is the best way to clean my MAF?
Old Dec 11, 2009 | 06:46 PM
No you can NOT clean your MAF, if you do it will kill it once and for all.
Once you order a new one and it gets to you then you can try and clean it.
Yes it is safe to drive, but it will act up and may leave you stranded.
www.roverlandparts.com
www.autosportsunlimited.com
Old Dec 11, 2009 | 06:51 PM
so the only PO 734 fix is a new MAF? They are $200, not the end of the world, I guess. I would prefer to know if this is for sure the culprit before ordering one, though.
Old Dec 11, 2009 | 07:00 PM
Then you will need to take it in to a shop and have it tested to find out for 100%.
When you buy a new one make sure it is a Land Rover original, if not you will have problems with it again.
You can get them cheaper than $200 though, just search around for them.
Old Dec 11, 2009 | 07:06 PM
went and wiped of the plug on top of the MAF and my service engine soon light has gone away......
Old Dec 11, 2009 | 07:09 PM
but i still have the "whine" there, which I was told was the LEV pump. But I have isolated the area where it is coming from and it is not the LEV pump. Can't figure out where exactly it is coming from, though. AHHHHHHH!!!!
TRIARII
Feb 4, 2013 11:03 AM
thegreekmason
Jan 11, 2013 11:31 AM
Classklown90
May 2, 2010 09:34 PM
humroot
Dec 27, 2007 10:45 AM
riderwoodrover
Nov 23, 2007 07:21 PM
