Point me in tge direction of a lift.
edit: hey when I check that website, all I see is 3" for d2 and 2" for d1. Am I missing something?
oyster, do you know of a discount? lucky8 list the 3" lift for $700
http://www.lucky8llc.com/Products.asp?ProductID=2171
Sorry, spencer I assumed D2 for some reason. Not sure if there is a 3" OME for a D1 (dont know much about D1's). They'd be the same springs, but the spring seats on the D1 sit lower than a D2. You might need to add 1" spacers to get 3". But really, a 2" should be just fine. go with heavy duty spring rates.
Call lucky8 for a lower price.
Offset radius arms
New panhard arm (longer to recenter front axle)
Castor corrected swivel *****
Yes, you can just get springs and shocks and see how it goes, but be prepared to spend 2-3 times more.
I wouldn't install a new steering damper until you know your swivel preload is correct, otherwise you may just wear it out quicker.
I went with a 2" suspension and 2" body lift so I didn't have to worry about a lot of steering geometry changes, but can still run as large tires as I'm interested in running.
I run 7.50x16's (32" OD) for off-roading. Have for the vast majority of the 35+ years I've been driving Land Rovers. Though I'm due for new tires before long and haven't decided what size, but something close as 7.50x16's are getting scarce.
I ran bfg 31x10.5x15 on my Meso when I had that. I want to set my D1 up nice.
So looking at 315's with the 33' od bfg's and lifting it to put the tires on and thought a 3" is what I need to go with. Am I wrong on that??
The Goose
The Goose
Well I plan to set it up right and don't really want to trim anything. I would also like to ad flares to help with offset or wider tires than the stock
Setting right means I will modify the axels and gear boxes once I learn how!!!!
The Goose
The Goose
