Poly Flex front end bushings
Old May 21, 2018 | 03:50 PM
TaylorCadence's Avatar
Default Poly Flex front end bushings
starting to get a wobble in the front end. No sign of play when someone is steering left to right while I check underneath. I’m going to jack it up and tug around on some things this week but thought I’d get a head start on bushing replacement ideas.
looking into poly flex for all the bars (if they’re the culprits). I counted 6 total, is this correct? Please tell me what I’m missing if not.
Anybody know where I can buy these online without purchasing the whole kit for every bushing known to man?
I found these so far:
https://powerflexusa.com/discoveryse...1995-2002.aspx
But thats all I got
Old May 21, 2018 | 03:58 PM
Ok wow now it shows up. When I was searching powerflex before the panhard bushes were the only ones popping up. Here are some more:
https://www.powerflex.co.uk/road-ser...%29-316/1.html
out of this list are the other bushings I need in their catalog? thanks.
Old May 21, 2018 | 08:12 PM
Sixpack577's Avatar
Keep in mind the upper/lower control arm bushings press out/in...and poly bushings can be stubborn going in, as they don't flex like rubber.
Old May 21, 2018 | 09:00 PM
weird, I’ve heard they just pop in because they’re more malleable than rubber. Don’t even need a press
Old May 22, 2018 | 06:49 AM
Sixpack577's Avatar
Some may press in easy, but I have fought with several of them.
And, they can't just pop in, if they aren't a press fit, then they're loose, and can't do their job correctly.
Old May 22, 2018 | 06:50 AM
Saturnine's Avatar
In my Audi days, poly bushings were.. Super annoying and hard to work with, you always had to lube the crap out of them and then wrestle them in a press.
I can't imagine LR would be any easier
Old May 22, 2018 | 12:13 PM
I had the wrong notion on these things then hah, so rubber bushing just slide in or I would need to press in? Any recommendation on what I should use instead? Just looking to do this job at home if possible, without constantly taking to a shop to fit bushings.
Old May 22, 2018 | 12:14 PM
dang alright, back to the drawing board!
Old May 22, 2018 | 01:48 PM
Sixpack577's Avatar
Rubber go in easier, but can also be a struggle.
Silicone spray and a big C clamp can usually get it done, but, sometimes you must have a press.
I'm just talking about control arms too, as sway bar and end link bushings are usually not a problem.
Old May 22, 2018 | 01:50 PM
Sixpack577's Avatar
You also get a stiffer ride on polyurethane, as it doesn't flex like rubber.
