Poor Mans 8$ CAI... Another Crappy How To
Old Jun 17, 2010 | 10:08 PM
Spencerfitch's Avatar
Default O
TEST RESULTS
Night
86*
With Duct [idle]
200* coolant temp
105* air temp
With Duct [Driving]
196* coolant temp
96* air temp
Without Duct [Idle]
206* coolant temp
128* Intake temp and climbing
Without Duct [Driving]
198* coolant temp
119* intake temp, SLOWLY dropping to 119 with 5 mins of driving.
Old Jun 17, 2010 | 10:10 PM
cranky's Avatar
thanks.
more expansion = bigger bang
I like it!
________
Web Shows
Old Jun 17, 2010 | 10:43 PM
Night 86*
intake temp driving 135 slowly dropping to 119 with continue driving. 5mins
coolant temp driving 198*
Intake temp idling 128* and climbing
coolant temp idling 206.
Old Jun 18, 2010 | 12:37 AM
Second2None's Avatar
Originally Posted by Spencerfitch
Here's a little test for ya.
Night
86*
200* coolant temperature (idle)
105* air temp (idle)
196* coolant temp driving
96* air temp driving
I'll get back in a few with the numbers without the duct.
EDIT: without duct
Night 86*
Nice! I like some real numbers. Thats a 23 deg. drop at idle AND while driving! I'd say that's pretty good.
The colder the air the more dense it is. The more air you can fit inside your combustion chamber, the more fuel the computer can throw in there, and the more power you will get out of your engine. Of course there is a limit on this when using force induction to stuff more air into the cylinder, because then the fuel injectors will need to be replaced with ones that can deliver more fuel and the ecu will need to know how to do that, so proper "tuning" will need to be done, in the form of a chip or a full standalone computer.
CAI is the simplest way to get more air into your combustion chamber. ..And no those ebay "Turbonators" dont do anything ..lol
Old Jun 18, 2010 | 01:03 AM
skatelove303's Avatar
K&N cold air intake, Why not get one of those and fit it on? How would that work with the maf sensor?
Old Jun 18, 2010 | 01:14 AM
K&N cold air intake is MEH.
Difference is 150$ AND..
It wouldn't help much.. IT would have a larger filter, with more area for air to enter which would increase flow, if flow out of the engine allows.
BUT
Temperature wouldn't be much difference. All theres does is makes a little wall around the filter. But how does the air get to the filter? There isn't much room for air to go around the headlight area and such. Basically temperature wouldn't change much if at all. This gets the air from FAR away from the engine. Meaning the only way the engine temperature effects it is by heating the air as it travels through the air system. Not only that but at higher speeds this is also a ram air intake, air in theory will have a higher pressure.
Supposedly resulting in more Horse Power, but what im interested in is fuel economy.
Old Jun 18, 2010 | 05:58 AM
Rovin4life's Avatar
You get colder air at the top away from the exhaust especially in traffic and the heat of the road.
Old Jun 18, 2010 | 06:07 AM
lipadj46's Avatar
I'm all for the sprite of invention and all that but... nevermind... shine on you crazy diamond.
Old Jun 18, 2010 | 02:41 PM
lipadj46's Avatar
I see you made the unfortunate mistake of posting this over on Dweb (twice), they are not as civil over there.
Old Jun 18, 2010 | 04:14 PM
Yes. Sadly I did..
See I come from the Toyota 4runner communtity where ideas are accepted. Sadly I see with land rover owners there not.
