possible head gasket?
I've been in my engine compartment a lot lately because I'm getting ready to change out my plugs and wires and I noticed what looks to be a little bit of fluid (looks like oil but not yet confirmed) on my right valve cover near the gasket. I'm going to clean my engine up today when it's cool so I can get a better look to see if it is "new" fluid or if it's been there and I just hadn't noticed it. My oil is clean and coolant levels are constant. What else should I be looking for? Can I let the vehicle run in place once I've cleaned the engine or do I need to drive it around the block a couple times to get the RPM's up?
Thanks
Thanks
RE: possible head gasket?
Since it is a D2, you can power scrub your engine at the local car wash, don' worry about getting anything wet cause nothing will effect a D2. By the time you get home it will be dry and then you can check it every couple of days for fresh seepage. Most likely you just have a leaking valve cover which is pretty normal.
deleon_daniel@sbcglobal.net
06-18-2010 06:04 AM
LikenDisco2k
05-03-2009 08:25 PM
Boos00disco
04-04-2009 02:24 PM
