possible head gasket leak
Old Nov 7, 2011 | 03:36 PM
Aaron, what are you going to do now?
Old Nov 7, 2011 | 05:47 PM
aarongregor's Avatar
Well Mike I have talked with you before when my drive shaft broke and the garage said I also needed a T case. When I called you, you said that my T case should be fine and low and behold it was. I am going to have the head gasket replaced as you advise. I could be leaking coolant onto a head as well I suppose but the exhaust does smell sweet. The shop that is going to check my ABS codes said he would check my head for $30 so I will spend the $30 but I do believe you are right. Sweet is sweet.
mike111
Jun 2, 2014 08:58 AM
samaro71
Dec 30, 2010 02:06 PM
LikenDisco2k
May 3, 2009 08:25 PM
bigugly82
Sep 5, 2007 05:10 PM
harmeson7
May 18, 2007 07:47 AM
