Possible Lug Stud Head Damage
Old 07-29-2017 | 08:01 PM
Jsivey's Avatar
Default Possible Lug Stud Head Damage
So the short version is that my brother-in-law was helping remove old rotors that were stuck on my 2004 DII and hit the lug studs in the process. They don't look too damaged, but the lug nuts won't fit on now. It's three studs total (one front right, two back right).
Is there a way a shop can re-thread them or even them out? I'd hate to have to buy new lug studs because of this, but at the moment that's what I fear is going to happen.
Otherwise, the hubs sound fine. No squeaking or squealing. Another reason I don't want to replace two entire hubs.
Old 07-29-2017 | 08:29 PM
OverRover's Avatar
Not the end of the world...get a M14-1.5 DIE and chase the threads. Be sure the die is set up straight before you chase/recut the threads. Good Luck!
Old 07-29-2017 | 08:30 PM
LR03NJ's Avatar
Yes as long as they are not bent.
Old 07-29-2017 | 09:16 PM
Jsivey's Avatar
They don't seem to be bent to one side. If you look at them straight on the tip is smooshed down on one side. I'm not exactly sure if it's the stud or the lug nut.
If it's an easy fix I'll take it to a local LR repair shop. I trust him to fix the stud and I'm sure he has a shoebox full of lugnuts if it's those that are the problem.
Thanka for the advise. I wanted to make sure it wasn't a hub replacement before I tried to fix it.
Old 07-29-2017 | 11:30 PM
KingKoopa's Avatar
Are the studs press fit or threaded? It's easy to knock out a press fit stud and pull in a new one.
Old 07-30-2017 | 06:04 AM
OffroadFrance's Avatar
Please don't quote me but I think they are splined for easy insertion. I'll check the RAVE for you.
PS: Take a look at this post.
Wheel Stud Replacement - Disco II - Land Rover Forums : Land Rover and Range Rover Forum
PPS: Fire the BiL and buy a 'donkey'
PPPS: Take a look at this, a lot of crap talked as usual but in amongst the chatter there are some useful bits.
http://forum.landrovernet.com/showth...eel-Studs-Help
PPPPS: (yawn) there ya go, they are splined studs.
http://www.ebay.com/itm/LAND-ROVER-D...-/182279832389
Roont (02-28-2024)
Old 07-30-2017 | 06:24 AM
Don't say I didn't try to sort it for ya eh
Old 07-30-2017 | 07:39 AM
Jsivey's Avatar
Much appreciated. I may be up to doing this myself now. Then again...
chubbs878
11-25-2016 11:27 PM
chubbs878
11-25-2016 03:42 PM
knightmetro
09-26-2014 08:18 PM
Rearden Steel
05-07-2012 08:23 PM
DrippyDisco
06-06-2011 11:57 AM
Quick Reply: Possible Lug Stud Head Damage
