Possible XYZ Switch failure.
Old Aug 14, 2010 | 10:28 AM
mgarcia0422's Avatar
Default output shaft speed sensor
did you get your problem fixed, cause we are having the same thing going on with our '00 Disco II, and we have the 3amigos. No local LR dealer in my area closest one is 6 hrs away.
Old Mar 8, 2023 | 10:42 AM
Txdisco2's Avatar
zombie thread revival here. I’ve got an 04 disco 2 going into limp mode without any codes…some say the CPS (crank position sensor) fixed their issues so starting there. Trucks RPMs will surge at random, so wondered if also the alternator, am going to check voltage on that as well.
Old Mar 8, 2023 | 11:45 AM
Harvlr's Avatar
If your alternator is giving low voltage that will cause transmission ecu to go into limp mode.
meltdowndave
Nov 5, 2019 09:02 PM
meltdowndave
Apr 28, 2019 09:53 AM
northernlilywhite
Nov 20, 2011 08:55 AM
RicknCody
Mar 28, 2010 07:49 PM
meltdowndave
Sep 26, 2009 11:18 AM
