Post filter change issues on 2003 Discovery
Old 06-23-2021, 09:38 AM
DiscoBuckeye's Avatar
How many miles were on trans and when was last fluid/filter change? Was there a lot of clutch plate material in pan?
Not that strange to have trans issues after a fluid/filter change, especially, if it has been well over a hundred K since the last one. Normally, if l do not know age of fluid and filter and trans is shifting/operating fine in advance...l causion on the side of error...drop fluid, only, refill using proper sequence, drive it for a few weeks, then drop pan and change fluid and filter second time.
Normally, you'd see/feel slippage after a fluid/filter change that was prolonged to the point of trans fluid being the only thing left in the trans that had fiction qualities. With yours, holding in gear longer and banging in between shifts...almost like you got a lot of debris lodged in valve body.
Unknown mileage 145+
Original fluid looked OK. SO what I have done so far is Fluid and filter change. Magnet had maybe an 1/8 of an inch of schmutz (issues started) Bought a Napa filter and changed it with new fluid again and almost nothing on the magnet. Just recently changed to an OEM filter because some thought I might have air in the fluid. Nothing on the magnet this last time. The last two times I used Valvoline synthetic ATF hoping it would free up the solenoid that might be stuck. No joy. I wish I was fearless and could remove the valve body and have a look but I am afraid springs and check ***** will go flying everywhere.
Atticus_6147
03-17-2017 12:05 PM
hothatch98
04-25-2015 06:33 AM
Russratt
09-16-2014 08:31 PM
caleb
11-30-2009 09:10 AM
73S3IP
09-07-2009 04:14 PM
Quick Reply: Post filter change issues on 2003 Discovery
