Potential New Owner ~ Need Help and Suggestions
Ok well thats good to know. I found a couple on Ebay, looks like about $300-$400 for a new rebuilt one with greasable joints.
So basically, the 2 major things to look out for on the D2 is the front propshaft and the heads leaking, correct? The other stuff is minor fixable sensors and wires it seems. Other than that they are pretty sound?
Also, I know they all take premium gas. Is that what most of you run? I have a hard time beleiving that most "average" owners actually put premium in there. Although I have no issue using it, and I likely would just for the extra power.
As far as running premium...it has nothing to do with power...these engines are aluminum and run very hot...premium burns at a lower temperature...I can pretty much say with confidence that everyone on this thread runs premium.
Go for it...you will not regret buying one if you keep up the maintenance...classic style on-road and excellent off-road prowess even stock.
Optimus...rebuilding the driveshaft is way cheaper; you will need 3 greasable u-joints and a centering ball kit. The whole job should cost $175-$200 max w/parts at your local drive line shop.
