Power seat issues
Old Jun 19, 2020 | 05:12 PM
merebel's Avatar
Default Power seat issues
Ok drivers side seat works strangely.
all functions only work at half movement when first get in. Start and run the vehicle stop and go shopping come back and then seats work normal. This is intermittently doing this. And frustrating for my wife.
any thoughts ??
Old Jun 20, 2020 | 03:12 PM
XRAD's Avatar
what do you mean 'half movement'? they only go half way up the track, or the buttons only have half function (forward, not reverse)........
You can clean the fuses. You can "unplug/plug in" the big grey plug and brown plug under the seat a few times. You can clean the switch /harness connections.....maybe your switch is worn out....
the basic layout for wiring is that Power goes to the seat via the brown plug, and the grey plug just forward/reverses current to the motors....
Old Jun 20, 2020 | 03:44 PM
merebel's Avatar
what it is doing is the normal travel works sometimes and others it moves about half or so it’s normal travel.
Old Jun 20, 2020 | 04:03 PM
XRAD's Avatar
so mechanical or electrical. Do the motors sound strained compared to other side? If no, then follow above and start cleaning contact points. Fuses are under the seat front end.
Old Jun 20, 2020 | 04:19 PM
merebel's Avatar
it doesn’t sound like a binding on something issue more like a lack of power strain.
Old Jun 20, 2020 | 05:16 PM
merebel's Avatar
Would the passenger side switch work with the drivers side if I move them around?
Old Jun 20, 2020 | 06:27 PM
XRAD's Avatar
no. they are semi-mirror images(I think this was my pin guide EU switches with full 8 way on both). and the harness is slightly different too...different sized grey plugs....most commonly in USA, the passenger seat is a 4 way, while the driver is an 8 way....
If you have an 8 way passenger, then maybe you can test it out, but you have to pull the seats to get the harnesses out.....
If you think it is a switch, they are only a few $$'s on ebay.... you can test switch continuity using a multimeter. The wires run in 'pairs' but I don't remember which ones go together....
erick846
Oct 1, 2015 10:23 AM
Mrcreeper3435
Feb 20, 2013 09:33 PM
fitch11
Oct 18, 2007 02:58 PM
P_vannortwick
May 15, 2007 06:15 PM
P_vannortwick
May 2, 2007 12:26 AM
