View Poll Results: What should I replace?
PS pump
0%
PS box
0%
Don't be cheap and just do both
100.00%
Voters: 3. You may not vote on this poll
Power steering failed, but which part?
Old Mar 12, 2023 | 12:33 PM
Broken08's Avatar
Default Power steering failed, but which part?
I have a lifted, on 35s 04 d2. My power steering has suddenly stop working without any warning of any kind. No weird noises no intermittent issues, it just stopped out of nowhere. When the engine is running and I open the reservoir cap I can see fluid moving and it moves more when I give it more throttle, which leads me to believe that perhaps the pump itself is still good. There is a little bit of oil on the steering box down low but nothing huge and obvious. And knowing that it's a Land Rover it could just be engine oil from some other leak, haha.
So how do I differentiate which part I should replace? I know the pump is cheap and easy compared to the box, but I don't necessarily just want to throw parts at it. How else would I know?
Thanks much in advance!
Old Mar 12, 2023 | 06:13 PM
Extinct's Avatar
Its the gasket on the back of the pump, that's were they alwasy leak from.
Old Mar 13, 2023 | 08:29 AM
Broken08's Avatar
Would a slow leak make it suddenly not work?
Old Mar 13, 2023 | 09:39 AM
XRAD's Avatar
sudden loss may be the piston seals or bad worm shaft inside the steering box, or the PS pump. Pump may look like it's pumping, but the pressure may be way too low. Hard to tell. Changing the PS pump is much easier than fixing the piston seals....
I would start with the PS pump. They are not terribly expensive...but some of the cheap versions have been know to leak. Maybe 'proline' is a better part?
Old Mar 13, 2023 | 06:34 PM
Extinct's Avatar
Only if it is out of fluid.
johnkbl
Sep 21, 2023 06:17 AM
cybercop
Feb 3, 2022 12:10 AM
zski128
Sep 26, 2021 05:25 PM
james.martin1
Sep 30, 2014 06:33 AM
kenk
Oct 7, 2013 07:45 AM
