Is power steering fluid caustic to main drive belt?
I have a 2001 Disco II SE7. The bearing went out on my power steering pump and leaked all over my main drive belt and surrounding parts. This will be the THIRD power steering pump that I have had to replace in about 4 years (each one dying about 14-16 months after being installed so no warranty). I'm not abusive to the truck, I don't go mudding in it, but I do live in Steamboat Springs, CO so there are a lot of switchbacks and mountain passes I cross, maybe this is stressing the pump. Anyways, my mechanic says I need to replace the main drive belt because the power steering fluid is caustic to the belt. The belt was replaced in June of this year and if I can avoid the 80 some dollar price of replacement this time, it would be great. Is this necessary? Also, are there any other parts surrounding the pump that I need to be concerned about with exposure to the power steering fluid? What is the best way to clean the engine without using the BS "engine cleaning solution" at the local do-it-yourself car wash? Thanks for the tips in advance!
