Power Steering Fluid Recommendations
Got my turkey baster ready, but scratching my head a little on what PS fluid to use...no discernible leaks anywhere, but I'm getting some groans here and there when travelling at low <5mph with engine/fluids cold...
Did a few searches and it seems that some swear by OEM LR fluid, while others are gung ho about any old synthetic fluid from the local auto part store...some say too to add PS conditioner and/or stop leak as well for good measure...
Help me out good LR folk.
It does not matter, buy whatever makes you feel good. I put the purple lubegard PS treatment (at Napa) in also because it makes me feel good. I'm not convinced a stop leak will even work on these pumps unless maybe on the front shaft seal.
I started using Royal Purple PS fluid when I did my first swap and it seems to work just fine. My cold steering creaks and groans were a little quieter and seemed less frequent with the RP, but could have just been the "placebo effect" and switching from dirty to clean fluid.
Synthetic or not, as long as the fluid is clean, you'll be fine.
Yikes, just did a price check on RP PS fluid at NAPA...expensive stuff!
Thanks for the responses guys...I'm leaning towards the MaxLife...I've used their oil in the past and it seems like they make good stuff...
@Spike - I'm guessing you mean that you like the by the book drain and fill method instead?
I did the "turkey baster" method, but I would say the drain and fill method would be more effective at getting out more of the old fluid, and most likely more of the dirt that settles at the bottom of the reservoir and lower hoses.
How spike would do it is remove the belt, take off the return hose from the tank and put it in a waste container, then spin the pulley with a drill and keep the tank full as the old fluid drains, then stop when clean fluid comes out the pump. Honestly though as PAS fluid is so cheap if you buy a gallon and use the turkey baster method 3 or 4 times you will have over 90% new fluid.
I tried using this method but nothing came out the pulley for the ps is upper right?
It's on the drivers side, yes. It would be the pulley to the right of the idler pulley. If you have ACE there would be another pulley above it. Also you will see the high pressure PAS line by the PAS pulley. Read the shop manual for drawings of the aux pulley arrangement.
