Power steering issue
Hi Mike
the noise is more like a fast clicking or ticking noise with the new pump. When I bled the system, we used about 1.75 quarts. So you think I should bleed another quart or 2 through the system?
Also - Should this noise go away without driving the car or do you need to drive it a bit? And would it hurt to drive it?
thanks
thanks
Hi silver,
i never put 3 to 4 quarts threw the system. I emptied the reservoir and put in new p/s fluid. Then bled it until the air was out of the system (or so it seemed). I kept the bleed screw open for another minute or 2 while turning the wheel back and forth (with a steady flow of fluid coming out), but this didn't cycle through more than probably 1.5 - 1.75 quarts. And the stuff coming out of the bleed screw is the new fluid I put it.
thanks
thanks
Hi guys,
I did empty most of the old p/s fluid out of the reservoir and the hoses, but that's it. I then added the new p/s fluid and bled it. It does look red and doesn't have any foaming or bubbles in the reservoir (which it did before I changed the pump).
I also followed the directions and set the screws with the correct ft lbs for the 3 screws, so they should be good.
Should I drive the car for a bit and see if the noise actually goes away? I would have assumed that once the pump and fluid has been changed, there wouldn't be a noise for a time as it works it's way out... And would me driving around do any damage?
That clicking sound is pretty annoying and I really don't want to drive anyway.
How would you get the the p/s fluid out of the gearbox? would that be the standard bleed I've been doing?
thanks for the info
thanks for the info
