Power steering issue
Old May 25, 2019 | 11:46 PM
longshot's Avatar
Default Power steering issue
This has probably been covered in a thread already but I couldn’t find it. My 2000 D2 with 78k miles is having steering issues. When I got it the pump was making noise so I replaced it with a new pump, no change. The fluid in both the steering and the ACE pump are moving like they should when the vehicle is running. I took it on a 150 mile run today and about 15 miles before home made a beer stop. As I was pulling into the corner store parking it became very hard to steer. I popped the hood and checked for problems. The fluid was moving like normal and there were no leaks. As I was leaving the store I noticed the steering was easier as the RPMs increased. Any suggestions. Thanks for the help.
Old May 26, 2019 | 12:15 AM
FlyingZebra34's Avatar
The pump shouldn't be making that much noise. What fluid did you use? There is ACE specific fluid. Sounds like air in the system and wrong fluid.
Old May 26, 2019 | 08:41 AM
longshot's Avatar
What is the correct fluid and how do I get the air out?
Old May 26, 2019 | 02:48 PM
Discorama's Avatar
Pls. use the search function, there are a few nice write ups on that.
Old May 26, 2019 | 07:30 PM
longshot's Avatar
I tried. I could not find anything to fit the symptoms I’m having.
Old May 26, 2019 | 09:14 PM
I'm not sure what fluid is compatable but look up Land Rover ACE hydraulic oil. Last time I messed with it, I lifted the front axle and ran it off the ground for awhile going left and right. There is a function using a scanner to activate the system to push air out. You might need a Land Rover shop if you can't get it to burp.
Old May 27, 2019 | 10:02 AM
longshot's Avatar
I’ll give it a shot. Thanks
Old May 27, 2019 | 04:36 PM
shanechevelle's Avatar
I used DeX 6 and my pump quieted right up...but then I also change my fluid every year as well. The thicker the fluid gets the more groan I've noticed.
Old May 27, 2019 | 06:19 PM
Extinct's Avatar
You probably need to bleed the box - there is a thread on it. I like to use a hose looped from the bleed screw back in to the tank to minimize the mess.
Old May 27, 2019 | 10:00 PM
longshot's Avatar
Thanks
