Power steering pulley HELP PLEASE
Old Aug 18, 2013 | 06:14 PM
Rferguson's Avatar
Default Power steering pulley HELP PLEASE
I got a new power steering pump installed on friday, I started the disco today for the first time since I picked it up from the repair shop and the belt snapped, I bought a new one and a mechanic friend of mine rushed right over to install it but noticed the power steering pump pulley is sticking out more than the others causing it to slip off. I do not own a second car and need to get to work in the AM. Is there anything I can do to make it in-line?
Old Aug 18, 2013 | 07:56 PM
So, have the shop that installed it pay for the repair.
Old Aug 18, 2013 | 10:43 PM
dr. mordo's Avatar
I can only think of one thing - they flipped the pulley backward when they installed it. I believe this would push it forward.
If I'm right, you'd have to break the three 10mm pulley bolts loose but don't remove them, then pull the belt, then remove the screws and flip the pulley. Reinstall the screws, finger tighten them, replace the belt, and tighten them as much as possible with a wrench.
Old Aug 19, 2013 | 01:21 AM
I'm thinking you thinking pretty good there, doc.
Old Aug 19, 2013 | 01:35 AM
dr. mordo's Avatar
Well, thank you.
I have the advantage of having replaced my pump two weeks ago, so I had to consider these things at the time.
Old Aug 19, 2013 | 09:25 AM
I would still send it back to the shop, let them pay to tow and fix it. If was installed wrong and they won't fix it for free, if you paid with a credit card, stop payment on them till it is fixed.
Old Aug 19, 2013 | 09:51 AM
And pay for your cab ride to the office
gundog
Sep 22, 2019 10:37 PM
gundog
May 8, 2014 07:03 AM
MntRover
Sep 15, 2013 10:01 PM
PJRover
Sep 13, 2013 05:29 AM
JakeVT
Oct 15, 2011 03:03 PM
