Power Steering Pump Dowel
Hi all,
I recently noticed that my serpentine belt was missing a rib. Seems the power steering pump pulley was coming out a bit. I was able to knock it back in line with a hammer, which helped for about 2 minutes. I ended up replacing the pump, and I decided to see if I could rebuild the old one. As I was taking apart the old pump, I noticed that the small dowel that goes into the indent of the shaft looked a little sheared. If anyone is familiar with rebuilding these pumps, can you tell me if that dowel should be symmetrical on both ends? If yes, does anyone know where I can get a new one?
Thanks!
Jamie
Thanks!
Jamie
Yea. It definitely isn't supposed to look like that. I have been searching all over for a exploded view of the PAS pump to no avail. I did measure the dowel, and it is a double taper, .157" diameter and .365" length. Pretty sure when you take wear into account, it is a M4x10 dowel pin. I might just need to buy that size and figure out how to make the tapers.
After really looking at the internals tonight, I am pretty sure that the only function of this dowel is to spin the "propeller" with the shaft. It doesn't hold the shaft in. I think the shaft is held in by the bearing only.
Per my post above, if anyone is in need of this dowel, it's 4mmx10mm, or a M4x10 dowel. I never could find the double taper, but my plan was to attach it to my drill and file the taper on both ends.
I think I'm going to reuse it. The pump will be a spare anyway.
losinov
03-21-2011 08:57 PM
