Power Steering Pump Leaking
Old Dec 23, 2019 | 08:26 PM
Bignacio's Avatar
Default Power Steering Pump Leaking
So, After replacing the t-case with an 04 setup.( Thanks Abran! ) I get the truck home and its dripping power steering fluid. The pump started whining alot. Anyway is there a preference when it comes to replacing the pump? Rock Auto, Ebay, AB? I'll replace the hoses also since I gotta take everything apart and probably the pully as well. . Thanks for any input...
Old Dec 28, 2019 | 12:27 PM
Carlos Man's Avatar
AB has a fantastic power steering pump instal video... it was painless.
got my pump on amazon.
buy a fluid extractor they cost like 5 bucks and suck out as much fluid as you can before you remove the hoses so you don’t make a mess.
change your pulleys and tensioner and belt while you’re at it they are all reasonably priced on amazon.
Old Dec 28, 2019 | 06:37 PM
Bignacio's Avatar
Im gonna follow the AB video. Not much simpler than that. What brand of pump did you get from amazon?
Old Dec 28, 2019 | 06:47 PM
Carlos Man's Avatar
It’s been a good purchase ever since... just got back from a 7 day 1,000 mile trip and it’s held up great. But like I said I also changed all the pulleys and tensioner. I have a water pump ready to be installed just haven’t figured out when I’m gonna do it since I’m changing out thermostat and some hoses. (Peace of mind project)
Old Dec 29, 2019 | 09:26 AM
shanechevelle's Avatar
If its leaking out the.back just reseal it. Take the back off, add some gasket sealer to the clear plastic gasket and put it back together.
The bolts aren't tight at all on the back so dont tighten the bolts or you'll freeze up the pump. You'll see what I mean when you take the pump off.
Old Dec 29, 2019 | 11:29 AM
Bignacio's Avatar
Thx, I'll be digging into it today!
Bignacio's Avatar
Thx, I'll order that. Its a lot cheaper than AB...
Reyesahr
Range Rover L322 (3rd Gen)
Nov 24, 2018 10:59 PM
BobE
Jun 27, 2016 04:31 PM
rangerover2008
May 12, 2015 11:50 AM
Hercu
Mar 9, 2015 07:48 AM
kenk
Oct 7, 2013 07:45 AM
