Power Steering Pump Whine
Old Jun 17, 2019 | 09:35 AM
redrover75's Avatar
Default Power Steering Pump Whine
Posted to the D1 on accident,
I replaced my ps pump and bled the system. Now I have a whine tied to engine speed. Could it go away over time? Self bleeding? No bubbles in the reservoir, although I did initially.
Ran another 32 oz of fluid through it this weekend, still getting a whine. I did get some foamy fluid towards the end of the flush.
I believe rave says not to turn the wheel when bleeding, another post said to turn the wheel. I have tried both, no luck.
Cleaned everything very well.
any other ideas?
Old Jun 17, 2019 | 06:04 PM
Extinct's Avatar
Put a hose on the bleed nipple, run it in to the tank. Run the truck and turn the wheel back and fourth until the whine stops.
Old Jun 18, 2019 | 09:59 AM
redrover75's Avatar
Great Idea!
thanks
Old Jun 19, 2019 | 04:50 AM
shanechevelle's Avatar
I added some dex6. It's been that way for a year. I think the whine is related to the fluid being to thick.
Old Jun 19, 2019 | 12:01 PM
Discorama's Avatar
What fluid did you use? I replaced my pump, did a flush and filled it up with Royal Purple (because it was recommended here). Now I have a slight whine at high rpm when turning the wheel. It's OK, but not perfect. Obviously the Royal Purple is not the right fluid, I should better go back to a manufacturer specified fluid.
Old Jun 19, 2019 | 02:18 PM
Motorhead1's Avatar
Mine works fine with a store brand Power Steering Fluid.
#1BRONCOFAN
Jan 18, 2014 12:29 AM
risky
Dec 10, 2012 05:29 PM
lipadj46
Sep 11, 2010 07:49 PM
lipadj46
Jul 13, 2009 09:26 PM
