Power Steering Reservoir?? What to do when need to replace and can't find one?
Old Nov 6, 2023 | 04:52 PM
Harvlr's Avatar
Maybe they mean the fluid in the reservoir?
Old Nov 6, 2023 | 11:48 PM
Brandon318's Avatar
Originally Posted by mln01
This a something of an aside, but I have always scratched my head about the maintenance schedule recommendation to replace the power steering reservoir at 150,000 miles.
Probably because the filter screen isn't replaceable. That's my guess at least.
Old Nov 7, 2023 | 11:04 AM
greisinb's Avatar
Power steering maintenance is the first thing I did (after CPS replacement) to my rover. Admittedly all I did was a thorough fluid change with Valvoline MaxLife fluid but it helped a lot. I removed as much of the old fluid as possible with a pump and filled it with fresh fluid. I then took it for a local drive and did a bunch of figure eights in a parking lot (I suppose this could be done parked in the driveway as well). It's important that you turn the steering wheel back and forth many times so the fluid in the power assist cylinder has a chance to purge out, which it only does when the wheel is actively being rotated. I repeated this process 2 more times, sucking out the old fluid and replacing it with new fluid every time. Yes, I did go through several quarts of fluid but I'm satisfied with the results.
hemicharger69
Mar 4, 2019 06:38 PM
tnkeith
May 20, 2018 03:52 PM
wyrdvans
Jun 24, 2016 11:59 PM
pkunze
Feb 11, 2013 06:49 PM
03DiscoSE
Mar 30, 2012 08:43 AM
