Power steering suddenly quits, then starts again?
Old Apr 21, 2021 | 09:13 AM
swissarmychainsaw's Avatar
Default Power steering suddenly quits, then starts again?
2000 Disco 2, petrol.
So last week I'm driving on a very twisty road, (fully loaded with camping gear, roof tent, kid, water jugs - 12 gallons, etc) and this happened about 4 times:
On the gas coming up to a curve, let off the gas to slow down through the curve and it feels like the power steering just suddenly stops working.
The steering gets very hard, and then it just "turns on" again.
Freaking scary.
Anyone have this happen?
(I don't have a power steering leak, have not looked into fluid levels yet)
Old Apr 21, 2021 | 04:34 PM
Has fluid in it, god only knows how old it is, but, that's weird right?
Old Apr 21, 2021 | 04:41 PM
Discorama's Avatar
Did it make a squeaking noise?
Old Apr 21, 2021 | 05:35 PM
No noise at all that I could tell!
Old Apr 21, 2021 | 09:48 PM
So some research shows this could be a bad PS Pump.
$250 at FLAPS, and $350 for the Atlantic British Unit.
Do you guys believe they need the Special ACE fluid or can I just run normal PS Fluid? The Atlantic British guys recommend the specal LR Only fluid @$24 per quart for the cheap stuff.
Thoughts?
Old Apr 22, 2021 | 12:24 AM
Discorama's Avatar
I am using Royal Purple power steering fluid. Pentosin CHF 11S is another option.
Old Apr 22, 2021 | 01:31 AM
rikkd's Avatar
Do you also have ACE? If your D2 has ACE I think (not 100% sure) you need a different fluid. An easy way to check if you have ACE or not is if you have a tank with 2 caps but fill the same tank
Old Apr 22, 2021 | 08:27 AM
That makes sense, No ACE here.
Old Apr 22, 2021 | 10:19 AM
Harvlr's Avatar
ACE or not, I don’t think you should use ordinary power steering. The Pentosin is expensive, but available from Napa.
Old Apr 22, 2021 | 10:24 AM
I'm convinced!
The question is, do I preemptively replace the PS pump?
