Power steering suddenly quits, then starts again?
Old Apr 22, 2021 | 01:12 PM
Discorama's Avatar
I tried ordinary PS fluid and it didn't work well. It can be used for flushing (empty reservoir & refill multiple times) though.
Old Apr 23, 2021 | 09:06 AM
dswilly's Avatar
Happening when letting off the gas could it be the belt slipping on the pulley? Or the pulley slipping on the pump?
Old Apr 23, 2021 | 09:16 AM
swissarmychainsaw's Avatar
Yes that's a good thought. The belt looks pretty worn, with some cracks in it.
I think I'll change the best and renew the fluid and go from there.
It's not leaking from the PS system, so...
Old Apr 23, 2021 | 10:14 AM
dswilly's Avatar
Might check the tensioner pulley too. Could be the belt/pulley combo causes a brief slip when engine speed abruptly changes under load.
Old Apr 24, 2021 | 05:13 PM
cvhyatt's Avatar
Yeah +1 on the pentosin. I just replaced my steering box for the second time. Also you may want to take a look at the power steering flush and fill sticky which can do wonders for your system.
Old Apr 25, 2021 | 04:10 AM
JUKE179r's Avatar
+2 for Pentosin.
Old Apr 25, 2021 | 03:07 PM
Fastercat's Avatar
Another thing to check is the U-joints on the steering shaft. They can stick or seize up every now and than if not lubed up and free
LR4play
LR4
Jun 14, 2020 08:17 AM
woodchip2bert
Mar 19, 2020 03:29 AM
Kitaf
Apr 1, 2019 02:55 AM
wmburney2004HSE7
Apr 5, 2014 08:35 AM
ian11
Freelander
Jun 11, 2011 07:00 AM
