Power Steering update
I got the pas pump by itself and where I thought the leak was coming is wrong. So I checked the other hose and nothing so I started looking at the pump itself. I noticed fresh fluid around the gaskets so I decided to unscrew the four botls and took the pump apart. I noticed there was a gap on the gasket where the fresh fluid was coming from but now I think I need a new pump because from what Im told there are no gaskets inbetween the two parts of the pas pump. In the first picture, the gap is on the gasket on the bottom. I was thinking it was on the other side or it could have fallen off but no pices fell off when I took it apart. The 4th pic to the right is where I originally thought the leak was coming from but there is no hole inside or outside the tube.
what do yall think?
what do yall think?
I was able to clean up one of the thin plastic seals and used the red rtv on both sides... letting it cure till tomorrow afternoon and then gonna see if it works! If not looks like Im gonna have to get one at the dealership... Its $423 minus a $110 core charge so $313 total and I dont have to wait for shipping.
I would suggest to use Hondabond #4, get this at the Honda motorcycle dealer .
This is a semi permeable sealing paste
It is perfect for joining aluminum parts and is chemical resistant more so than the RTV is. IIRC a 4.5 oz tube is about 12.00.
Just make sure to remove all the oils from the assemblies to be joined, and dont use a glob as it will squeeze out, you dont want to plug up a check valve
johnnyjohnny
09-26-2019 09:37 PM
DiscoBritney
12-19-2011 06:24 PM
losinov
03-21-2011 08:57 PM
jycsalas
04-17-2009 02:21 AM
