power steering went out--'03 Discovery
Old Jan 5, 2010 | 03:12 PM
kpl1228's Avatar
Default power steering went out--'03 Discovery
Very cold in NE Ohio. Anyway, For one day my power steering sounded like a '72 Chrysler's power steering...lots of high pitched squealing. Now it's gone: both the noise AND the power steering. Everything else is ok, incl. power brakes. No warning lights, nothing.
Questions:
1) Can I drive a Discovery without the power steering without further damge to the vehicle? I drove it home when it died and it's not easy, but it's do-able.
2) What could it be? Fluid levels look good.
Old Jan 5, 2010 | 03:48 PM
rankar's Avatar
sounds like your power steering pump gave out. check out the rave manual for the process on replacing it (you'll need to replace the pump and then bleed the system properly; both fairly easy to do).
as for driving it without pas, don't know.
guys, what do you think?
Old Jan 5, 2010 | 05:55 PM
kpl1228's Avatar
Old Jan 5, 2010 | 06:53 PM
lipadj46's Avatar
You can get a used power steering pump from autosports unlimited for $70 shipped with the pulley.
Old Jan 6, 2010 | 05:04 PM
kpl1228's Avatar
ok very good...i'll look into it thanks
Old Jan 6, 2010 | 06:11 PM
Do not drive it till you verify what is wrong. Is your p/s fluid still churning in the bottle, when did you last service it last.
Old Jan 6, 2010 | 07:31 PM
If the pump went out yes you can drive it.
If the pump has run dry then no, you cannot drive it.
If you (or somebody else) added power steering stop leak it will clog the system when it gets cold if there is to much stop leak in the system.
It gets to thick and cant pump.
Old Mar 30, 2010 | 07:08 PM
betsymichael's Avatar
4th Gear
Default pulling my power steering pump on 03 disco
I've taken off the ac, the belt and the pulley. I've got the two bolts out of the front of the steering pump and the nut off. How do you get the stud out the nut was on?
Old Mar 30, 2010 | 07:19 PM
thehulk's Avatar
Had this exact problem... you kinda have to twist and pull its way out. Try not to damage the fan. The ideal route to go would be to remove the fan and that would give you plenty of room to slide it out.
Old Mar 31, 2010 | 09:53 AM
4th Gear
The diagram I have makes it look like the stud goes out the back, and why would it have a nut on the front if it comes out the front?
