Power window motor only operates in one direction
Old Oct 6, 2008 | 04:32 PM
bcolins's Avatar
Default Power window motor only operates in one direction
My 2002 Disco right rear window would not go down. I pulled the door apart and pulled out the motor and regulator assembly and hit the switch and nothing happened in either direction...........took the switch off the other rear door and tried it.............no change, pulled the motor off the regulator,...and took it apart to check the brushes etc and re-assembled. With the motor NOT attached to the regulator it turns in one direction. I tried the switch from the other door...........same thing..motor only turns in one direction.
At this point I decided to post here before going further, but while posting,...........I realized that I had another motor sitting on the bench from my right front door which was apart for other window issues...........grabbed that motor and plugged it in and curiously,..........it only turns one way also..............Anyone experienced this problem............Im guessing that the problem is somewhere in my wiring????
Any ideas??
Brian in Austin. [/align]
Old Oct 7, 2008 | 05:15 PM
roverguy7's Avatar
Default RE: Power window motor only operates in one direction
try swapping front switches, the ones for the rear windows, power goes through them to get to the rear switches
Old Oct 8, 2008 | 03:34 AM
bcolins's Avatar
ORIGINAL: roverguy7
Just to clarify, are you suggesting that I swap the front and rear switches on the passenger side,.......or are you suggesting that I swap the front switches right to left?
Brian
Old Oct 8, 2008 | 10:06 PM
tacomatech's Avatar
Swap the right front switch with the left front switch, then check operation of your faulty window. If it works properly, then you will need a new right front switch. Double check this to see if the problem switched doors. (By "front switches for the rear windows" we mean the rear window switches that are located on the center console) Power goes through these switches first, then through the rear door window switches, then to the window regulator motors.
Old Oct 11, 2008 | 08:23 PM
bcolins's Avatar
ORIGINAL: tacomatech
I did the swap and lo and behold, might right rear window started working in both directions. Curiously,....when I switched them back to their original positions............everything still worked in both directions.........shades of old Lucas wiring!!
Thanks for the tip.
Brian
bcbp
Oct 20, 2012 12:27 PM
grandkodiak
Aug 21, 2012 02:14 PM
Spencerfitch
Jul 21, 2010 10:04 AM
RoveringAgain
Jun 28, 2010 10:14 AM
