Prev Maintenance/Replacement PS pulley?
Old Aug 6, 2013 | 11:57 PM
Rover_Hokie's Avatar
Default Prev Maintenance/Replacement PS pulley?
I have already replaced the water pump with pulley, belt tensioner, and have the bearings to replace in the 70mm & 80mm idler pulleys here soon. I have not had any issues with my PS pump and have replaced the fluid in the past 6 months and added Lucas PS conditioner at that time.
Is there some preventative maintenance I can do on the PS pump pulley? I have not worked on the PS pump on the D2 except to drain/fill PS reservoir to refresh with new PS fluid. So I am not sure if the pulley can or should be replaced, or it is just replaced when you have to replace the pump some day, or is the pulley something I can do as preventive maintenance at 150K mile like my other items?
Old Aug 7, 2013 | 12:31 AM
Do it with the pump.
CJP-DiscoII
Apr 19, 2011 01:34 AM
DirtySE7
Engine & Internal
Nov 28, 2008 09:31 AM
marcolanza
Mar 10, 2006 03:58 PM
Shay108258
Aug 5, 2005 04:05 PM
