prob #1...cylinder 2 misfire
Old Nov 15, 2009 | 05:26 PM
iownme's Avatar
Default prob #1...cylinder 2 misfire
Oh woe is me...just travelled 1200 miles and have few tools to work with!.
i wrote here a few weeks back about a cylinder 2 misfire, i was advised to change plugs and wires..which i did and the problem went away until i got 1200 miles away..now i have the same fault code.
It drives a little rough, and i can feel a misfire occasionally while driving, it does seem to be running on all 8 cyl's mostly...but i can feel an occasional skip throughout the rev range....i'm hoping?? its a bad coil pack or injector, but how can i be sure which?... i put in another newplug today but that didn't fix it...any ideas?
I'm posting another problem with brakes shortly!
Old Nov 15, 2009 | 05:41 PM
What brand plug and wires did you install, what octane gas are you using, have you been having to ad coolant to the engine lately and what is the exact fault code do you have?
Old Nov 15, 2009 | 08:06 PM
iownme's Avatar
i used champion plugs (regular ones as i heard platinums are just a marketing hype) and the wires were "premium" from napa, I'll check the brand name in the morning and post. I was using regular octane, but recently changed to premium.
My bud did top off the coolant b4 the trip...i'll check with him tomorrow how much he added, the fault code is PO 302
The vehicle has been off the road for about 8 months...it was throwing a lean code, but since i've been using premium octane that seems to have gone.
__________________
Old Nov 15, 2009 | 08:33 PM
Most likely it will be the cheap Napa wires. You have to use good quality 8 mm wires or they will fail.
Regular plugs will last up to 30,000 miles, good platinum plugs like Plus 4's and daul Platinum's can last to 100,000 miles, so don't believe everything you read, plus base plugs need more voltage to fire, making them less effective.
Old Nov 15, 2009 | 08:34 PM
lipadj46's Avatar
You should have taken the advice that I'm sure was given to you when you asked the 1st time around. Magacor 8mm wires (from apex performance) or if you are on a budget then try kingsborne.
Old Nov 15, 2009 | 08:40 PM
SpdDemon426's Avatar
Ya, it sounds like its arching..You are losing spark some where...
Old Nov 15, 2009 | 08:52 PM
iownme's Avatar
the wires are 8mm performance wires....i opened the hood in the dark to see if i could see arcing (like i did when i found the original problem) before i replaced the wires i saw arcing at the coil pack. after changing the wires i see NO arcing anywhere in the dark with the hood open.
I did not have time to find the wires suggested previously...i was leaving for GA the next day...it was napa premium or nothing
Old Nov 15, 2009 | 09:45 PM
iownme's Avatar
well one test i just thought of that no one mentioned is to try swapping 2 wires around to see if the misfire changes cylinders....i find it hard to believe that the new #2 wire has coincidently died after 1200 or so miles, premium brand name or premium napa. I think the coil is to blame...if not the coil then an "iffy" injector.
Another test i'll try..(appears I am on a roll with ideas tonight) will be to disconnect the #2 wire, attatch a spare plug to it, ground the plug and watch for spark action...and compare to spark action on a known good wire.
Is #2 plug 2nd LHS from the front of the engine?
Old Jul 29, 2012 | 04:54 PM
chorizote's Avatar
5th Gear
I have been thinking on changing spark plugs and wires, going with your post, i searched for 8 mm wires specific for LR discovery 2, and could not came up with a set that said that it was 8 mm, most just say its premium wires. Can i used one of those universal sets from "orreally" 8 mm wires sets? The reason i want to changed the wires is because some times i will get a "service engine soon" and a little bit of shaking but then i will go away. I figured i could do the wires and spark plugs and then maybe the coils.
Julian
LR disco ii, 108K miles
scarrell
Nov 16, 2012 06:04 PM
Newbie1989
Jan 17, 2011 07:32 PM
rover
Freelander
Apr 28, 2008 08:42 PM
xb70valkarye
Oct 23, 2007 12:50 PM
lajilana
Sep 2, 2006 10:47 AM
