Problem fixed
Problem fixed
I've had an annoying problem with our 2001 V8
it all started about 2 months ago...firstly the fob(remote key) wouldn't lock all doors ....then when I tried the key in ignition... no lights and no start
each time the truck would not start I would take the positive lead of the battery
then the alarm would sound and the ignition lights where all on and the truck would start
I cleaned both the battery terminals and cleaned all the earth connections but still no luck... the problem still there sometimes the key would work and other times it didn't..also tried new battery in key...still no fix
I read the workshop manual(down loaded from this site..THANK YOU ) flicked through many of its 1600 pages ..learning lots but not identifying my problem
I then decided to book it in to (Gold star mechanics) to be diagnosed ..quote $77 to maybe find the problem
i turned up to Gold Star...Paul the mechanic takes one look at the battery and says change it ..this looks to be the problem...telling me that most cars can run with a half decent battery but the Land rover relies on a fully charged one to run properly
so I buy a new battery and my problem is solved...just thought i would share this with you all...now I'm happier than ever
cheers Corey
cheers Corey
i did charge the old battery and thought it had enough charge, there is a green indicator on the battery and it was lit but a little dull...i didn't end up paying for the mechanic and the battery cost $175 for a 900 cca three year warranty
my original thoughts were that it would be costly as I thought it was the immobiliser or something to do with a door sensor or the ECU
cheers corey
herblatham
01-28-2010 03:29 PM
