Procedure for using Amigo V2?
Old Aug 21, 2013 | 02:55 PM
FlyingZebra34's Avatar
Default Procedure for using Amigo V2?
Does one exist? What do the different flashing lights indicate?
Old Aug 21, 2013 | 03:40 PM
Never heard of it, what sort of scanner is it and what lights are flashing?
Old Aug 21, 2013 | 05:45 PM
Its the normal amigo device that plugs into the OBD2 port then stores the codes on the device, then you read them on your computer.
Light flashes red, then green/blue, then green then you pull it out and connect to the computer.
It cleared the codes off the land rover but I'd like to know what they were.
I'm also trying to get them to come back but no luck yet.
Old Aug 21, 2013 | 05:48 PM
Bosshogt sent the instructions, thank you though Mike.
Old Aug 21, 2013 | 07:29 PM
dusty1's Avatar
I'm also trying to get them to come back but no luck yet.[/QUOTE]
cool, sounds like some crazy jedi robot, that you plug in and then it repairs all problems. i need one!
Old Aug 22, 2013 | 12:56 AM
I got them back, all I had to do was think for five seconds "well maybe they're gone for good"
Old Aug 22, 2013 | 08:43 AM
I was one of the original people asked to test the 3 Amigo Scanner,V@, just never heard anyone referring to them as a V2.
That being said, what is the actual question about the flashing lights? When plugged in, the scanner goes through a 5 second communication with the computer, reads and clears the codes and as already mentioned then you just plug it into your computer and read the fault code numbers which are printed below.
Main Menu
Home
Discovery II - D2
Discovery III - LR3
Range Rover - Sport
Range Rover - MKIII
Range Rover - P38a
Range Rover - Classic
FAQ
News
Off Roading
Web Links
More about Me
Key Vehicle Concepts
P38a EAS System
P38a EAS Faults
P38a EAS Diag Videos
P38a EAS Unlock Videos
Disco II ABS System
Disco II ABS Faults
Disco II ABS Plugs
Disco II ABS Videos
Disco LR3 - Videos
MKIII EAS System
MKIII EAS Faults
MKIII ABS Faults
MKIII Repair Videos
Disco I - ABS Codes
General
Disco II ABS Codes
Title Filter Display #
# Article Title Hits
1 114:Shuttle Valve Switch Electrical Failure 5762
2 113:Shuttle Valve Switch Dynamic Failure 2710
3 112:Internal ECU comms error 1836
4 111:Shuttle Valve Sticking 1655
5 110:Sticking Throttle Detected 1339
6 101:Brake Light Relay Drive Short to Supply 1183
7 100:Pump Relay Drive Short to Supply 1103
8 097:Rear Left Out Valve Drive Short to Supply 857
9 096:Rear Left In Valve Drive Short to Supply 852
10 095:Rear Right Out Valve Drive Short to Supply 788
11 094:Rear Right In Valve Drive Short to Supply 846
12 093:Front Left Out Valve Drive Short to Supply 852
13 092:Front Left In Valve Drive Short to Supply 827
14 091:Front Right Out Valve Drive Short to Supply 846
15 090:Front Right In Valve Drive Short to Supply 826
16 Rear Right Sensor Bad Output 1118
17 Front Left Sensor Bad Output 1394
18 Rear Left Sensor Bad Output 1113
19 Front Right Sensor Bad Output 1826
20 081:Brake Light Relay Short to Supply 848
21 080:Pump Relay Short To Supply 699
22 077:Rear Left Out Valve Short to Supply 780
23 076:Rear Left In Valve Short to Supply 705
24 075:Rear Right Out Valve Short to Supply 771
25 074:Rear Right In Valve Short to Supply 752
26 073:Front Left Out Valve Short to Supply 688
27 072:Front Left In Valve Short to Supply 705
28 071:Front Right Out Valve Short to Supply 703
29 070:Front Right In Valve Short to Supply 723
30 067:Rear Right Sensor Electric Fail 936
31 066:Front Left Sensor Electric Fail 949
32 065:Rear Left Sensor Electric Fail 791
33 064:Front Right Sensor Electric Fail 1045
34 061:Brake Light Relay Short to Gnd 706
35 060:Pump Relay Short To Gnd 678
36 057:Rear Left Out Valve Short To Gnd 667
37 056:Rear Left In Valve Short To Gnd 659
38 055:Rear Right Out Valve Short To Gnd 669
39 054:Rear Right In Valve Short To Gnd 630
40 053:Front Left Out Valve Short To Gnd 680
41 052:Front Left In Valve Short To Gnd 661
42 051:Front Right Out Valve Short To Gnd 640
43 050:Front Right In Valve Short To Gnd 657
44 047:Rear Right Sensor Output Low 976
45 046:Front Left Sensor Output Low 1297
46 045:Rear Left Sensor Output Low 1215
47 044:Front Right Sensor Output Low 936
48 041:Brake Light Relay Open Circuit 1264
49 040:Pump Relay Open Circuit 864
50 037:Rear Left Out Valve Open Circuit 716
51 036:Rear Left In Valve Open Circuit 615
52 035:Rear Right Out Valve Open Circuit 1034
53 034:Rear Right In Valve Open Circuit 647
54 033:Front Left Out Valve Open Circuit 645
55 032:Front Left In Valve Open Circuit 730
56 031:Front Right Out Valve Open Circuit 647
57 030:Front Right In Valve Open Circuit 697
58 023:Gear Info Not Valid 774
59 022:ECU Gnd or Reference Gnd Bad 2046
60 021:Engine PWM Signal Bad 1688
61 020:No Batt Supply Voltage 1032
62 017:ECU Internal Valve Relay Bad 924
63 016:Shuttle Valve Switch Long Term Failure 1477
64 015:Pump Fail Pump Running When Not On 956
65 014:Pump Fail Pump Sticking 1017
66 013:Pump Fail Pump Not Running When On 786
67 012:Pump Fail Monitor Line 1108
Old Aug 22, 2013 | 02:06 PM
Ok I finally pulled the code from the Rover, 114 so electrical failure. I swapped out the switches and replaced the seals with falcon works little kit 8 months ago.
The day the codes came back on was extremely hot and was traversing the desert out in southern cali.
Any thoughts?
Old Aug 22, 2013 | 03:07 PM
Read the codes again.
Old Aug 22, 2013 | 05:18 PM
Re ran the codes and I have 114 consistently coming back without any other codes.
