Programmers for D2 for tire size/gear reprogramming?
Old Jan 4, 2013 | 11:44 PM
Bkreutz's Avatar
Mine doesn't get a lot of miles, I do my service intervals by time. But like jafir said, it's not enough of a difference to be concerned with. (or you could consciously err on the short side, doing a service early doesn't hurt)
Old Jan 5, 2013 | 07:17 AM
I worked out the numbers, years ago running 265" with 4:11's and my odometer is off by 11% and my speedo id off by 4 MPH.
Old Jan 5, 2013 | 07:45 AM
wkburns's Avatar
Originally Posted by Shade Tree
TruSpeed™ Speed Sensor Recalibrator · Superlift · www.superlift.com
Doesn't say anything about working on a Land Rover, did you call them?
Your welcome!
I had been researching them some prior to this post. Yes they do work as a few people on other boards have installed them. I am not doing it for mileage, but rather so the ECU is corrected as to what the engine is doing vs speed. I am interested to see if it affects shifting points. If it does not at the very least my speedo will be correct again. Model number 33002 module B is the one that works for us.
Old Jan 5, 2013 | 07:50 AM
Bigger or smaller tires or gears will effect the shift points as well as low end torque and MPG.
As for doing your services, you should all consider doing them early for better wear protect and longevity.
Old Jan 5, 2013 | 10:51 AM
SuperSport's Avatar
Here is a cheap used one I just saw on eBay $70:
Superlift Truspeed Speed Sensor Calibrator | eBay
Old Jan 5, 2013 | 11:48 AM
jafir's Avatar
One thing about a D2 only tire size affects the speedo. Gears come before the wheel sensors.
Old Jan 5, 2013 | 12:01 PM
coors's Avatar
I run 265-75/16's, up from stock 255-70/16's, my speedo (and I assume my odometer) is off approximately 5.3%.
Old Jan 5, 2013 | 12:18 PM
antichrist's Avatar
Originally Posted by Spike555
I have often wondered this, how do you guys with larger tires adjust for MPG and total miles driven?
So if you are running oversized tires and you calculate your miles are you also doing the math to bring your numbers to the proper MPG?
I'm just curious.
Spike, on D1's you just change the speedometer drive gear if you're worried about it.
Old Jan 5, 2013 | 02:51 PM
No I'm not worried about it at all, I run OEM sized tires.
I was just curious if these guys factored it in or not was all.
Old Jan 5, 2013 | 03:40 PM
jafir's Avatar
32" tires were OEM for land rover on defenders and camel trophy discos.
