Prop Shaft Bolts
Old Jan 23, 2009 | 04:52 AM
tomfraser's Avatar
Default Prop Shaft Bolts
I'm doing a prop shaft that has so much play (u joints, are pretty much gone/destroyed) that the shaft actually took chunks out of some of the bolts (pictures when I get the god damned thing out)
So I need to cut 2 of the bolts (one off the front of prop shaft, one of rear of prop shaft)
Does anyone know what type of bolts and nuts these are? Are they a standard bolt found in home depot, or will I have to go to a land rover dealer?
Thanks
Old Jan 23, 2009 | 07:15 AM
unimoged's Avatar
Default RE: Prop Shaft Bolts
NAPA has these bolts, if you are far from an LR dealer. Take yours in and they will match them.
Cannot use the hardware store variety, too soft and not enough tensile strength / hardness.
Old Jan 23, 2009 | 09:02 AM
brooksa's Avatar
Anywhere that has Grade 8 3/8-24 X 1 1/2 bolts with Nyloc nuts
Old Jan 23, 2009 | 12:06 PM
Disco2Guy's Avatar
Don't the d/s bolts have some sort of a wax coating on them?
Old Jan 23, 2009 | 01:59 PM
JBEGIN's Avatar
[quote]ORIGINAL: Disco2Guy
[/quote
no they use those aircraft bolts
Alex_M
Sep 7, 2024 05:21 PM
Fireman
Sep 28, 2010 12:39 PM
blcp86
Jul 24, 2009 07:49 AM
jw928
Feb 28, 2009 10:26 PM
aaveryy
May 12, 2007 07:51 AM
