Prop Shaft Greasing
Old Sep 3, 2013 | 05:53 PM
UtahExplorer's Avatar
Default Prop Shaft Greasing
Hey everybody,
I've got a Tom Woods shaft installed in my 04 disco and I'm trying to grease everything up but there is one flush zerk that I can't reach without taking the prop shafts off (it is inside one between the two ujoints). So my question is, how do I take the rear prop shaft off? I removed the four bolts that attach the shaft to the emergency brake drum but I couldn't collapse the shaft to get the shaft to drop. If I remove the four bolts that attach the shaft to the rear diff, will that be enough to get the right angle to get into the cordon unit?
I don't know if I'm explaining it the right way.
Anybody know what I'm talking about?
Old Sep 3, 2013 | 06:28 PM
ZGPhoto's Avatar
Rear? Do you have a rear DC shaft? It should be nuts you're taking off the rear drum, not bolts.
mylesman12
Oct 9, 2012 05:48 PM
Grumpo
Aug 29, 2012 12:17 PM
lordmorpheus
Jun 6, 2010 07:28 AM
josemex
Aug 3, 2009 04:38 PM
chad420
Jul 5, 2009 10:27 AM
