Greasing a drive shaft
Old Aug 28, 2012 | 05:40 PM
Grumpo's Avatar
Default Greasing a drive shaft
The grease fitting that came with my Tom Woods driveshaft is made of plastic and does not seem to want to snug up to the fittings enough to make a good connection. The grease goes everywhere but in the driveshaft fittings.
Anybody have any tricks or recomend a specific brand/part # for a fitting for a pistol grip style grease gun?
Old Aug 28, 2012 | 07:37 PM
antichrist's Avatar
Most any auto parts store. NAPA usually has them.
Old Aug 28, 2012 | 08:21 PM
Remove your "grease zerk" and take it to NAPA like Tom said, a assortment pack of 10 is like $5.
Old Aug 28, 2012 | 08:27 PM
Grumpo's Avatar
Good idea. I bought one from pep boys but it didn't do the trick either.
Old Aug 29, 2012 | 06:29 AM
ebg18t's Avatar
Dont take this the wrong way, but you did take the plastic/rubber cap off the zerk?
Is the end if your grease gun fitting securely on the zerk? You should feel it click onto the zerk.
Old Aug 29, 2012 | 08:20 AM
Grumpo's Avatar
I don't feel any clicking. When i press against the drive shaft fitting with the grease gun fitting it usually slips off half the time. Has to be a better way. I waste so much grease trying to lube that thing Im second guessing myself weather or not the thing is full.
Old Aug 29, 2012 | 10:09 AM
antichrist's Avatar
Does the zerk look like this
or on this?
If the former you need this kind of tip
or
Read my Propshaft Rebuild post on how to properly grease u-joints. "Filled" isn't really a description that would apply.
Old Aug 29, 2012 | 12:17 PM
909wheeler's Avatar
Are you popping the plastic cap off the zerk fitting first? I don't think I've ever seen a "plastic zerk" however I have seen many plastic caps.
RobG4
Jul 27, 2013 07:38 AM
mylesman12
Oct 9, 2012 05:48 PM
lordmorpheus
Jun 6, 2010 07:28 AM
josemex
Aug 3, 2009 04:38 PM
chad420
Jul 5, 2009 10:27 AM
