PROS and CONS
Old Sep 2, 2007 | 07:02 PM
disco ii hse's Avatar
Default PROS and CONS
Ok just a few questions about CDL, my discoII is CDL capable and all I would need to do is add the linkage from a disco I and was even thinking of adding an actuator, then I was knocking about the ARB web site and saw the air lockers they have for the disco my question is what are the pros and con of going ARB instead of just going with a OEM set up. Thanks in advance for your help..
Old Sep 2, 2007 | 08:03 PM
okdiscoguy's Avatar
Default RE: PROS and CONS
The CDL only acts on the T-case. It locks the front and rear drive shafts together. The ARB lockers lock either the front or rear diff, wherever you put it. Right now, without traction control, you could spin one wheel. I would start with a solenoid actuated CDl then move to the ARB if needed.
Old Sep 2, 2007 | 08:35 PM
So I assume if I actuate the CDL and add the ARB air lockers I could lock on the fly.. in either hi or lo..
Old Sep 3, 2007 | 08:45 AM
NO
To engage the CDL, you must **** from High to High or Low lock. To prevent gear damage, shift to Low lock from a stand still or shift from Low to high under 10 MPH.
What type of 4 wheeling will you be doing, do you need something as hard core as the ARB lockers, have you thought about a Detroit or better yet True Trac's?
Old Sep 3, 2007 | 09:25 AM
I planed on doing some trails locally, a bit of rock crawling, and then a few cross country trips with a friend, I also would like to unleash the hidden potential of my Disco. being a Marine and having driven the military version of the hummer, I was not to impressed by the Civilian version, and I had owned rovers in the past and have loved their ruggedness which far supersedes most any 4 wheeler I have driven, the only reason I choose the ARB is because a friend of mine was visiting from Melbourne and she told me that ARB would be best suited for my ride, do you know how big the price difference would be for the other lockers you mentioned and of course performance.
Old Sep 3, 2007 | 09:46 AM
So here are my rough numbers,
2 ARB , pump and HD rear axles installed $3250
One Detroit, one TT and HD rear axle installed $ 2650
Two True Trac's and labor, no HR axles required $1950
Give me a shout if you want to talk about the prices , the differences and any questions.
By the way, I run a Detroit and a TT.
303-862-7680
Colorado between 7 am and 8 pm
Old Sep 3, 2007 | 10:50 AM
thanks mike i have a few more questions but will call you to sought them out... thanks again..
johnkbl
Jan 19, 2010 05:22 AM
kfx4001442
Jan 24, 2009 05:32 PM
tj
Mar 22, 2008 09:20 AM
prospective owner
Jan 14, 2008 08:04 AM
TRANSAFRICA109
Jan 8, 2008 05:46 PM
