ProShaft Front Drive Shaft
Old 01-26-2013 | 06:00 PM
mongosd2's Avatar
Originally Posted by antichrist
I put flush fittings on them, but as long as there's 1/8-1/4" clearance there shouldn't be any issue with a regular zerk. If the propshaft moves side to side you have bigger issues and the cat isn't going to move much.
had to put a cap on a couple trucks because when they welded up the cat's at the factory,they weren't tucked up close to the frame...Also if you have worn or broken motor mounts and don't catch it, it's gonna hit. It's a 1 dollar part and a a couple of minutes to cap it...
  #152
Old 01-26-2013 | 06:01 PM
ZGPhoto's Avatar
I still have mine on unfortunately... maybe I'll go down to the shop and cut it off tonight haha. Mongo, I have my disco in the shop right now, what photos do you want?
  #153
Old 01-26-2013 | 06:07 PM
mongosd2's Avatar
just of the shaft on the truck showing how much of the spline shaft is exposed...just pull the zerk, it sucks when they get buggered up and you have to drop the DS to fix it...
  #154
Old 01-26-2013 | 06:24 PM
ZGPhoto's Avatar
Here you go. You can also witness some very beautiful grease work that I had to clean off haha.
  #155
Old 01-26-2013 | 06:33 PM
TRIARII's Avatar
Can you guys elaborate on your concerns here? Im lost now. I dont have a lift of my own so its difficult to take pics of the underbody, but my new propshaft is installed and it looks pretty much like ZG's. Again the only thing I am worried about is how close the grease fitting on the tubing of the shaft is to the cats. I ulled the little rubber cap off to re-grease it and have not put it back on because I assumed the cats would melt it.
  #156
Old 01-26-2013 | 06:35 PM
ZGPhoto's Avatar
That's what mongo and Tom were saying, fill with grease and install either a flush mount grease nipple or a blanking plug.
  #157
Old 01-26-2013 | 06:42 PM
jafir's Avatar
ZG does your driveshaft hit that cross member?
  #158
Old 01-26-2013 | 06:46 PM
ZGPhoto's Avatar
Most likely yes when off roading. That's why many have cut it off, as I will soon.
  #159
Old 01-26-2013 | 06:47 PM
mongosd2's Avatar
Is that sitting on the ground on a lift (drive on lift?)? Looks like it may have rubbed on the front crossmember at some point
  #160
Old 01-26-2013 | 06:49 PM
ZGPhoto's Avatar
Sitting on the ground, me laying under the truck. I believe you are correct, it does look like it's rubbed the useless X-member there.
Quick Reply: ProShaft Front Drive Shaft
