PSA: Carry an extra Crank Position Sensor!
Old Jan 16, 2016 | 10:26 PM
Alex_M's Avatar
Default PSA: Carry an extra Crank Position Sensor!
It's 30 degrees, my disco has yet to heat up inside. I just got my header install finished, I'm checking it out. I need a new gasket, but that's not the point right now. I'm cruising along, she sounds great. Doing my second WOT test. That's wierd, I felt a definite power increase on the first pull. Wait, I'm slowing down. Sh*t, engines dead. Pull over, no power steering, no power brakes, tiny median. I'm stopped. Try to start it again, nothing. Key off, one more try. She starts for a second, then sputters. Give it some throttle... Maybe... Nope, dead again. Try again, just cranks. Hop out, look around, can't see anything. Hop back in, crank, tach isn't moving. Crank position sensor.
I've got a parts truck I've been meaning to pull the CPS off of for months just to keep in the glove box, but I never did. Now I'm stuck waiting on a ride in the cold. This is a fair warning. If you've been putting off buying an extra, don't.
Old Jan 17, 2016 | 12:51 AM
toofaroffroad's Avatar
Thanks for that. I've got a brand new spare in my garage at home. I'll throw it in the truck from now on.
Old Jan 17, 2016 | 01:24 AM
Alex_M's Avatar
You're welcome! Hopefully you never find this helpful on the side of the road.
Old Jan 17, 2016 | 01:44 AM
number9's Avatar
Default Practice
The CKP sensor is the most important sensor on the vehicle and without its signal the engine will not run.
Have thought of picking up a new one to install as PM and practice, keeping old one for a spare. Not something I'd be wanting to do for the first time on dark side of road.
Old Jan 17, 2016 | 08:07 AM
Best4x4's Avatar
Yep my Kalahari has 224K on it, and I doubt it's cruising around on the original, but after buying it I stopped by Auto Zone and got one for 60.00 (40.00 minus my 20.00 reward $$). You'd be happy to know the "Duralast" branded box actually contains a genuine Bosch sensor!
Old Jan 17, 2016 | 09:08 AM
Alex_M's Avatar
Yep, definitely wouldn't be fun in the dark and cold with a hot engine and exhaust 20 inches off the 4 lane, especially for the first time.
Well Auto Zone here I come for my new extra!
Old Jan 17, 2016 | 09:18 AM
dgi 07's Avatar
Quick fix, dump water on it. It cools down enough to start and move to a safer location.
Old Jan 17, 2016 | 12:05 PM
Alex_M's Avatar
Luckily, we've got roadside assistance on our insurance. The tow truck came this morning and hauled ot to our driveway and im working on it now. Any tricks to getting the plug unplugged?
Old Jan 18, 2016 | 12:46 PM
evoblade's Avatar
We need to make a list of parts needed to keep in your truck:
CPS
flexible driveshaft coupling
brake switch
Anything else?
Old Jan 18, 2016 | 02:48 PM
number9's Avatar
Originally Posted by evoblade
Anything else?
The tools required to change the parts.
