Pulley Noise? How to replace it?
Old Dec 6, 2020 | 07:38 PM
Fanuvkorn's Avatar
Default Pulley Noise? How to replace it?
Old Dec 6, 2020 | 09:36 PM
redwhitekat's Avatar
Not sure which one is making noise but the tensioner and 2 idler pullies Atlantic British has the kit
Old Dec 6, 2020 | 09:52 PM
escott16's Avatar
This should help you figure it out location wise.
Old Dec 7, 2020 | 12:40 PM
Fanuvkorn's Avatar
Thank you!
Old Dec 8, 2020 | 03:50 PM
Fanuvkorn's Avatar
Default Well this sucks
**** the bed right as I pulled up to my shop.
Old Dec 8, 2020 | 04:08 PM
ahab's Avatar
Better than on the freeway, 20 miles from the nearest exit!
Old Dec 8, 2020 | 04:15 PM
escott16's Avatar
I guess you figured out what the problem is. The worst is when somethings wrong and you can’t find the problem and you just pray something breaks so you know what it is
Old Dec 9, 2020 | 04:57 AM
JUKE179r's Avatar
While you have the serp belt off check all your pulleys for wear, loose or noise.
I found my tensioner pulley (#1).had a crack in the plastic that I could see daylight through it.
floydclowser
Aug 6, 2019 02:42 AM
fellipe
Nov 6, 2015 02:17 PM
AdrenalinPlease
Jan 22, 2013 03:48 PM
G4-Rover
Nov 29, 2011 04:51 PM
DiscoIIBrandon
Feb 7, 2011 08:29 PM
