pulling the T case today
Old Mar 20, 2014 | 01:40 PM
FlyingZebra34's Avatar
Default pulling the T case today
I want to replace most of the leaky seals and front output bearing.
I figure my order of operations is pull the interior and disconnect the cdl, then pull the frame supports and y pipe, disconnect the driveshafts and then remove the bolts holding it to the transmission.
Am I missing anything? Is it impossible to pull the flanges from the t-case when its on a table?
Old Mar 20, 2014 | 01:48 PM
ZGPhoto's Avatar
I've pulled flanges off an LT230 when it was on a shelf, no worries.
Old Mar 20, 2014 | 01:52 PM
Good to hear. Are there any tricks to the case? Any snake oils I should get before pulling it apart?
If its as easy as the engine I won't have any issues.
Old Mar 20, 2014 | 02:18 PM
ZGPhoto's Avatar
Make sure you drain it first
Be careful when refitting, it's easier than you think to break off part of the tranny...
Old Mar 20, 2014 | 02:48 PM
DiscoJ's Avatar
Great thread, I'm preparing to do basically the same thing to mine.
Are there any special tools needed for disassembly/reassembly of the case or can it be overhauled with the basics?
Old Mar 20, 2014 | 04:28 PM
Does anyone know the size of the nut on the flange?
Old Mar 20, 2014 | 04:32 PM
ZGPhoto's Avatar
31mm IIRC
but I don't really RC
Old Mar 20, 2014 | 07:13 PM
Dane!'s Avatar
I might do this also, I'm leaking from somewhere, I think it's the fill plug though. Do take pictures though please
Old Mar 21, 2014 | 12:49 AM
I'll try to get a decent right up. Seems no one on disco web has pics either.
Old Mar 21, 2014 | 05:30 AM
Lowest Bidder's Avatar
I did mine last month, and I made a little stand that bolts under the lower cover so that I could lift it with a motorcycle jack. I saw that in the Rave and I thought it was a good idea. The LT230 is a pretty big and heavy case, and while removing it is not too bad, I would say it must be pretty hard to put it back on without damaging the new seal, depending on your setup. Having the case on a jack allows you to lower it slowly and see if there are still things attached to it.
