Pulsing Lights? 1996 Disco
Old Oct 20, 2008 | 07:36 PM
preple's Avatar
Default Pulsing Lights? 1996 Disco
hi I am new here. I just replaced the engine on my 96 Discovery. Now my lights are pulsing brighter and dimmer? Any advise? Thanks any help would be greatly appreciated! George
Old Oct 20, 2008 | 07:42 PM
Default RE: Pulsing Lights? 1996 Disco
Check the accessory belt routing, it is very easy to put it on wrong but it looks right.
http://www.roverparts.com/TechTips/s...g_defender.cfm
Old Oct 22, 2008 | 05:00 AM
preple's Avatar
OK,THANKS! I had the belt on wrong....but It made the pulsing worse? My codes are saying Misfire on 5 and 8? I cannot tell it is misfiring?
Old Oct 22, 2008 | 06:53 AM
Ok, sounds like maybe your 2 mis fires are shorting out to the block and the big electrical drain is causing the pulsing.
Go around and check and make sure that all of your plug wires are seated properly to the plugs and the coil's.
Then go and have your battery and alternator tested.
Let us know what you find. You might need new plug wires.
Old Oct 22, 2008 | 03:49 PM
JerrodSteph's Avatar
I had the pulsing lights issue too on my rover (96) because I was strapped for cash and I was bored one day I tore that alternator off and took off the plastic back to expose the brushes/regulator etc I cleaned everything up really good and sanded/ dielectric greased all connections from the alternator. Now the lights do NOT pulse and I didnt have to shell out the bucks for another alt...yet.
Externet
Sep 10, 2013 04:01 PM
wheelgarage
Jun 30, 2011 11:53 AM
brian891
Aug 24, 2009 10:12 PM
ctar
Jul 16, 2007 07:12 AM
KevinJec21
May 2, 2007 08:23 PM
