Purchased new driveshaft, few questions.
Old Oct 4, 2018 | 11:39 PM
Jason_B's Avatar
Default Purchased new driveshaft, few questions.
I purchase the British Parts of Utah rebuilt driveshaft. I understand the fittings at the u-joints. I pumped some new grease in there even though it seems packed full of grease.
My questions are:
  • How do I know I have greased the slip shaft part? I see a nipple and pumped a few pumps of grease in there but I did not see any come out. How do I know its “full”?
  • I noticed there was a female looking fitting (flat against the shaft) instead of a nipple and it seemed like there is a different color (brown instead of red). This is where the double u-joint part of the drive shaft comes together. Like a ball and socket type thing. See picture below.
As always, thanks. I am always learning new things here!
Old Oct 4, 2018 | 11:50 PM
Jason_B's Avatar
I am talking about the flat gold one, not the silver nipple with red grease.
Old Oct 5, 2018 | 12:20 AM
tcr6v1's Avatar
thats for greasing the center ball. Use a needle attachment for your grease gun
Old Oct 5, 2018 | 07:10 AM
R0VERGUY's Avatar
Yep, what the person above said is correct. It is a grease fitting, but a different attachment than the others is needed to grease it. The center ball grease point is a very positive thing and a big plus on upgraded shafts. If you keep that driveshaft greased properly it should last you a lifetime.
Old Oct 5, 2018 | 09:23 AM
Jason_B's Avatar
Thanks, that makes sense. I will see if my new grease gun came with a needle fitting.
Also, when greasing the nipple on the shaft part (not the u-joint) will grease come out of anywhere when it is full?
Old Oct 5, 2018 | 11:11 AM
R0VERGUY's Avatar
If you put enough grease in there I'm sure it will eventually come out where the shaft spline meets in the middle. I believe there is a seal there that you will start to see bulge. I'll crawl under my truck in a bit and double check and snap a pic if possible.
I wouldn't over pack it with grease. I would give it a good 10 pumps and drive it so the grease gets slung everywhere. From then on grease it every few months or after deep water, and just a pump or 2 like you would the others at that point. Just my way of doing it, not sure if it's right or wrong
back9sunday
Jun 9, 2016 01:52 PM
Dane!
Feb 23, 2014 06:51 PM
FlyingZebra34
Dec 16, 2013 03:38 PM
chad420
Jul 5, 2009 10:27 AM
kjordan
Mar 25, 2009 10:01 PM
