Push Button Start
Old Apr 15, 2019 | 10:05 AM
  #21
NewToTheTwo's Avatar
I suppose one concern I might have is how would you bypass this if it failed now that the cylinder is removed?
Our Hyundai had keyless entry and push button but had a manual bypass if anything failed.
I'm just assuming that most other keyless entry/push button start cars have some sort of bypass for a worst case scenario.
Old Apr 15, 2019 | 10:31 AM
  #22
mollusc's Avatar
i don't know of a bypass system on any push-button start car that i've driven.
but keyed ignitions don't typically have bypasses. why should there be one for a keyless system?
aside from hotwiring it, that is. which would basically be the emergency workaround if you add a keyless system. with the bonus that you wouldn't have to worry about the steering column lock.
Old Apr 15, 2019 | 10:43 AM
  #23
Understood -
So after Googling - which I probably should of done to refresh my memory first - I found that what I'm thinking of is a key slot to use in the event your fob is dead or the car isnt picking it up by RFID.
You stick the fob in the slot then start the car.
In the case of the OP's push button system, if the ring doesnt pick up the chip for some reason, how do you get the car started??
Old Apr 15, 2019 | 10:57 AM
  #24
mollusc's Avatar
i don't think the fob can be dead in this case. the rfid chip doesn't have a power source.
but your question is nonetheless relevant -- what if the antenna loop shifts and can't pick up the fob signal, for example.
i'd guess that what you do is hotwire it.
Old Apr 15, 2019 | 11:31 AM
  #25
mln01's Avatar
Which, we can now learn to do with the wiring information above. And I echo that getting rid of the steering column lock is a plus. Hotwiring does no good if the steering is locked.
Old Apr 15, 2019 | 11:36 AM
  #26
XRAD's Avatar
I looked up the install. Says to leave the key stub in the ignition. I did not like that part. unless you can pull it out in the 'on' or 'acc' pos......
This disengages the lock.
But I still like the idea....
Old Apr 15, 2019 | 12:50 PM
  #27
mollusc's Avatar
if you remove the entire lock barrel mechanism -- which you apparently have to do in order to get to the wiring -- doesn't that remove the steering lock as well?
sure you can keep the key stub in the ignition, but it's going to be sitting on the workbench not doing much...
Old Apr 15, 2019 | 12:51 PM
  #28
JUKE179r's Avatar
I wonder if this is like my BMW ignition where I can hit the start button without foot on brake to turn on the accessories like the radio.
Old Apr 15, 2019 | 12:56 PM
  #29
jdbayer's Avatar
Yes. Push the button once and it is in ACC mode.
Old Apr 15, 2019 | 01:03 PM
  #30
JUKE179r's Avatar
Cool! Thanks!
