Push rods - am I just checking to see if they're bent?
All the rods are out of the truck (middle of head gasket replacement) - am I just basically inspecting to see if they're bent as a criteria for replacement? They all have a small flat spot on the end about the diameter of a q-tip shaft, but they're all the same in that way too. One isn't anymore worn than any other.
To check if they're bent, just roll them on a piece of glass or any other flat surface like a countertop.
I hope you kept track of the location from which each pushrod came so you can reinstall them in their original locations. That's recommended.
I did indeed, yep.
