Putting In New Springs
Old Jan 15, 2008 | 03:23 PM
sailorcolin's Avatar
Default Putting In New Springs
Hey i have a 1996 disco 1. I am getting lifting springs that are 2 inches higher than stock. Just wondering if i do this my self do the springs have to be conmressed to get them out and put the new ones in?
Old Jan 15, 2008 | 03:46 PM
scadjoey's Avatar
Default RE: Putting In New Springs
It will definitely make your life easier to compress the springs... I haven't done it on mine yet but everyone that has replaced springs or lifted their rides have compressed them
Old Jan 15, 2008 | 05:21 PM
llesra's Avatar
if you take off the sway bars, the axle will drop enough so you wont need a spring compressor
Old Jan 16, 2008 | 01:34 PM
will that work with stiffer springs?
Old Jan 16, 2008 | 06:05 PM
llesra's Avatar
yup
Old Jan 20, 2008 | 07:35 PM
98GRDisco's Avatar
5th Gear
You can also use a bottle jack to get more space. just Lift the disco as high as you feel is safe the put on jack stands then locate a good place to put the bottle jack then just use the jack to push down the axle
Old Jan 20, 2008 | 09:31 PM
ORIGINAL: sailorcolin
What lift are you thinking about using?
rchrd0413
Apr 22, 2014 02:18 PM
Ross Landiepanzer
Jan 7, 2013 04:55 PM
ScottM
Jan 31, 2007 01:35 PM
Chaosislife
Apr 28, 2006 10:32 AM
Mee
Aug 11, 2005 12:43 PM
