Question about diagnostic tools and brake bleeding
Old Apr 27, 2019 | 08:50 PM
Jsivey's Avatar
Default Question about diagnostic tools and brake bleeding
So I finally got the 3 amigos and it came with the bonus of the hand brake light and a p1590 code. My first thought was to check the brake fluid. It looks like a rodent has chewed on the cap some, not bad enough to completely open it up, but I'm replacing it either way. I tested the brake fluid and it's at 3% so I know I need to replace the brake fluid ASAP.
My question is: Since I need to flush the brake fluid AND turn off the 3 amigos in order to get my tags renewed (thank you Tennessee) should I just bite the bullet and buy a diagnostic tool? I don't know of anyone near me (I've asked before) that has one I can borrow, and the independent mechanic will charge more than what it would cost me to do it myself. I've seen people mention the Autel al619, the Hawkeye and the Foxwell NT510 (the ABS Amigo seems like it's a one trick pony). Is there one that's better than the others? I'd prefer not to spend too much on one, but I also want to get one that's going to stick around for a while.
Does anyone have experience with any of those 3?
Old Apr 27, 2019 | 10:40 PM
mollusc's Avatar
i have the icarsoft lrii that has seen me right for almost everything i've needed a code reader for on this truck, at a much more manageable price than the ones you mention. i had to borrow one to do programming for things like converting from air springs to coils and turning off superlock, but it will read codes for all of the systems and will reset errors,
p1590 could be from a bad wheel sensor. i was able to diagnose that with the icarsoft, including which wheel was the problem one.
Old Apr 29, 2019 | 11:14 AM
mr. choodles's Avatar
Foxwell NT51 user here. Seriously that + UltraGauge are the most important tools you can have. Highly recommend getting both of them. For Foxwell NT51, you can download software for other cars, so if you have a few vehicles in the household, it'll pay for itself.
Old Apr 29, 2019 | 11:43 AM
JUKE179r's Avatar
If you plan to hold onto the Disco, get a good diagnostics tool.
Nanocom > Foxwell NT520 > iCarsoft > paying a garage to do it
Old Apr 29, 2019 | 11:54 AM
Jsivey's Avatar
I actually bought a Foxwell NT520 over the weekend. It had really good reviews so I bit the bullet. I plan on keeping the Disco as long as it will have me. It got a new engine at 80k so I have less to actively worry about.
Old Apr 29, 2019 | 12:56 PM
Best4x4's Avatar
A 15ft piece of wire (a pair), and a toggle switch = quick & easy to power bleed a D2 by jumping the relay.
Old Apr 29, 2019 | 02:50 PM
wjsj69's Avatar
I think doing what best said^ is even easier than using an obdII tool, but I also got a Fuxwell 520 for other things. Well I got Fuxed, well. It does all the basic stuff; gets/clears ABS codes, can change some settings, activate bleed, etc, but getting it to do anything else is a crapshoot and not very intuitive. You def. get what you pay for and for the price it's not bad, considering I got a deal with software for my other car too. But it doesn't do everything for that either..
Old Apr 30, 2019 | 01:58 AM
JUKE179r's Avatar
Yep.
This is exactly what I used for the longest until I got the Foxwell and Nanocom to power bleed my brakes...
And inserted the spades into the #3 & #5 sockets of ABS relay R10 under the hood...
Old Apr 30, 2019 | 07:31 PM
Extinct's Avatar
I have the Delphi DS150 - about $35 on ebay, full bleeding, abs diagnositics, code clearing.
Old Apr 30, 2019 | 10:13 PM
mln01's Avatar
What software does it come with? Do you need to use it with a Windows computer?
